cdjazman
- Apr 24, 2012
I have to give a shout out to Roosta (Nic) for the work he put together on his thread below;
https://auschristmaslighting.com/threads/8510/
After reading through and asking Nic heaps of questions I have decided to setup a "Central Command" for my display for this year.
I have started planning out today and thought I would keep a running log of progress.
Today was mainly planning and layout config.
For my setup I use the Pixlite16 Long Range so have receivers in the yard for data.
The power supplies will have positive connected to 8 way fuse box from Supercheap (containing 30amp fuses)
**Not the $10 one they have on the website - $19 in store.
The negative will be run to a 16-Way 100A Brass Distribution Bar sourced from Jaycar.
https://www.jaycar.com.au/16-way-100a-brass-distribution-bar/p/SZ2004
From the fuse box and busbar I have the wiring run to a 2 wire pigtail. I plan to have pigtails for all elements there so I can unplug power injection leads in the "off-season"
For the wire I have used a power lead that I have stripped and used brown for positive and blue for negative. I am thinking of using power lead for all my injection runs so keeping it color coded could help down the track. And I know what I have plugged in where......
Also have 5 port switch and Raspberry Pi to mount as well.
Happy for any thoughts - suggestions - corrections - ideas - etc......[/attach]
