Hey All,
I am a first time pixel enthusiast and I was wondering if you could have any comments on the buy list below that I am missing/haven't thought of?
I am just trying to cover all bases as a first order, to ensure that I have enough to play around and see what I like. Some of the quantities may be excessive but its a first pass which I can build on later. Miscellaneous items include cat 6 cable, 12V DC fan, CR1225 Battery, heat shrink, mounting boxes + grommets/waterproof penetrations and mounting gear (any others) which I am hoping to get at Bunnings / Jaycar as required.
Parts List
Controller: Standard White Falcon F16v3 controllers
Link: https://www.pixelcontroller.com/store/index.php?id_product=48&controller=product
Comments: Darylc has some left over that I might be able to take one off his hands.
Lights:
18AWG wire 100pcs/string DC12V square type WS2811 addressable RGB led smart pixel node, with all BLACK wire,IP68 rated
50pcs/set square type DC12V addressable 12mm WS2811 RGB led smart pixel node; BLACK 18AWG)wire,IP68; 0.2m xConnect/13.5mm pigtail
Link: https://www.aliexpress.com/item/4000827940470.html?spm=2114.12010615.8148356.9.6b9d33f2d14zA1
Link: https://www.aliexpress.com/item/32622651925.html
Comments: What is better, the square type or the bullet type? (I was going to get 5 x 50 and 5 x 100). I was thinking of avoiding the strip lights based on peoples comments around durability/reliability. Some prop sites say they prefer bullets, other say they they can fit both.
Mounting Strip: Plastic mounting strip for 12mm pixel nodes, 50m/roll,1 inch(25mm) hole spacing
Link: https://www.aliexpress.com/item/4000340164510.html?spm=2114.12010615.8148356.1.567d45b3RqFFmw
Comments: Where is the best place to buy mounting strips? This is the only type that Ray Wu has, I think it will fit the square type lights above. I know that the lights have a 4" spacing, it just means there will be plenty of cable sitting out the back, is that too much?
Power Supply: LRS-350-12;12V/350W meanwell switch mode led power supply;AC100-240V input;12V/350W output
Link: https://www.aliexpress.com/item/32493366099.html?spm=2114.12010615.8148356.6.4d05552aX58YBL
Comments: I was going to get 2 of them, which based on the 101 guide is slightly underpowered for all 750 lights, so I may need to get more in future.
Plugs: 10pcs/lot xConnect 3 Core BLACK Waterproof pigtail,50cm long each;male and female;xConnect(HC);18AWG wire
Link: https://www.aliexpress.com/item/32901737170.html?spm=2114.12010615.8148356.40.37e47833SLUe5r
Comments: xConnect 3, I preferred the longer females for coming off the controller, the males will end up being spares.
End Cap: 10pcs/lot plastic end cap for the 13.5mm BLACK waterproof pigtail
Link: https://www.aliexpress.com/item/1019809775.html
Comments: Just to cover the exposed ends (if any).
Power Tee: 10pcs/lot (3-2-3) xConnect 3 core T type waterproof splitter(the middle is 2core);with 2 core male;BLACK color;for power injection use
Link: https://www.aliexpress.com/item/32947628043.html?spm=2114.12010615.8148356.54.7aea7ceaBlroWI
Comments: I am not sure what my voltage drop is going to be like, so I was planning on being on the safe side to make sure that if I have glitching issues, I can just inject more power when needed.
Null Pixel / Signal Booster: DC12V WS2811 "null" pixels to regenerate the data signal with xConnect 3 core black waterproof pigtails
Link: https://www.aliexpress.com/item/32920869031.html?spm=2114.12010615.8148356.42.7aea7ceaBlroWI
Comments: I read previous threads which suggested that other manufacturers of these pixels would be better quality, these should be okay for a first time user.
Cable: 10pcs/lot BLACK 7.6m(25feet)3 core waterproof extension cable,one end with male,the other end with female,male connector's diameter:13.5mm
Link: https://www.aliexpress.com/item/1343250586.html?spm=2114.12010615.8148356.28.37e47833SLUe5r
Comments: I was considering the cable rolls and terminating myself, but looking at the cost of the pigtails + cable, the pre-terminated sections were only a couple of USD more expensive. I may have excess cable, but it is a lot easier having them pre-terminated. Thoughts?
Pixel Tester: SP501E LED Wifi pixel controller;support Amazon Alexa Smart SPI Voice APP Control for Andriod/iOS DC5-24V;waterproof pigtials
Link: https://www.aliexpress.com/item/4001299702938.html?spm=2114.12010615.8148356.10.e8e8392cNk4QKp
Comments: Was trying to get a tester with what looks like xConnext pigtails.
@Snitz87, did you have any thoughts mate?
In terms of light mounting designs, I will work on those for round 2, the idea for now was to get enough to have a decent play and can be built on in future.
Thanks so much for your help guys! You are all legends!
Cheers,
Kieran
Parts List
Lights:
Cheers,
Kieran
