Exhaust at top left, at time of recording the lid wasn't on ( no cover).Where are your supplies exhausting? Bottom? If so, there may not be enough room for the air to escape as it looks like the supplies are flat on the surface. (This is only on observation of the video and may be off base.) If air can't escape, then the fan blades cavitate. Much noisier than a fan in free air.
If I have to replace the fan, should I chose bearing or sleeve type?Would it be reasonable to assume these are cheap off-brand supplies? Regardless, My opinion is one or more of the following: supply fan bearings bad or fan is low quality (blade design and/or bearings), no supply fan control (the fan is always full on), rigid mount to base, base is acting as a sound board, and/or the enclosure itself is amplifying the sound (an acoustic resonance as it were).
If these are yours and you are trying to fix the problem I would first replace the fans. Find one with the same mounting size/pattern of course but a fan with a low db noise rating. Also keep an eye on the cfm (air volume throughput: Cubic Feet Per Minute) that is try not to sacrifice cfm to gain lesser noise. Least favorable choice is an acoustic sealed enclosure which will be a pain to deal with.
Do you buy them from ebay?Like David I am now moving towards the maglev fans for inside the PSU's, and use the cheap sleeve ones I still have for case ventilation as they are easier to swap out when they fail.
Yes, I think I paid about $9 each plus some delivery for the Maglev fans and about half that for the sleeve fansDo you buy them from ebay?
ThnxYes, I think I paid about $9 each plus some delivery for the Maglev fans and about half that for the sleeve fans
Sorry, I wasn't clear. Where are the fans on each of the power supplies (not the one in the box)? I see the grill work just above power connection screws (probably air intake) and the power supply body appears to be solid. I have several power supplies similar within which the PS fan is on the bottom, pulling the air through and then shoving the air down.Exhaust at top left, at time of recording the lid wasn't on ( no cover).
