Lumen
- Jun 30, 2018
Hi,
my spec is as follows:
- 12 RGB pixels which will be placed separatedly
- spacing between them is around 2 metres, where I have a 4 x 3 grid (covering thus an area of around 8 by 6 metres)
- LEDs should have good colour precision and strong brightness, angle as wide as possible
- installation must be weather proof
- LEDs must be controllable from a Raspberry Pi
So after asking around, basically everyone recommended that instead of getting a PWD board for the Pi and driving RGB LEDs individually, it would be advisable to use auto-addressable LEDs such as WS2811 style. My thought is to buy a strip and cut them individually, then extend them with rather thick copper wires (e.g. 1.5mm per wire) to minimise power loss, and also go for 12V rather than 5V. So would something like this work: https://www.amazon.de/gp/product/B01JTW6BPW/ - 12V Digital Full color RGB LED Exposed Light String 12mm WS2811 Digital Led Pixel Module ? Does 12V mean I have to transform the Pi's data signal also from 3.3V up to 12V, or would a Logic Level Converter to 5V suffice?
There's also these professional things https://www.enttec.com/eu/products/...rproof-16mm-opal-dome-white-rgb-5v-pixel-dot/ - Enttec 9PDOT8, only they are too expensive; they might be an option if I find a variant that just packages 25 instead of 50 units and cuts the price in half. I understand I will have to budget a controller as well, and a USB-to-DMX for the Pi, in this case.
Any thoughts? Thanks!
