Hello,
I have been using an older dell laptop to run my shows. It has worked great until I added a 16 string mega tree last year. I noticed during the christmas show that there were 3 & 4 min in between some songs. I had people drive off thinking the show was over. I decided to use a new laptop this year. I am running LOR S4 advanced software. I am using 3 lor controllers, 1 lor cmb24, 1 pixlite 16, 1 alpha pix 4 & 1 alpha pix 16. I also have a network switch. The lor is connected to the usb port. I have the network switch plugged into the ethernet port like the other laptop. I went into LOR network setup and set it up the exact same as the previous laptop. I also gave the laptop a static ip just like the other laptop. I am also able to go into the command prompt and ping all my controllers just fine but when I play a sequence only the lor lights come on and no pixels will work. if I plug the old laptop back in everything plays fine? I am sure I am missing something stupid. It has been 2 years since I set up the old laptop so I am sure I am missing something?
Thank you,
Robin
Thank you,
Robin
