pixel burst into flames!
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by elnino, Dec 3, 2014.
  1. elnino
    elnino Full Time Elf
    Aug 1, 2014
    137
    0
    This is a pixel from a brand new string from Ray. First time i powered it up but it was outside so i didnt notice it frying. I cut the pixel out and the rest of the string is still fine.
    Manufacturing fault?
  2. AussieDoug
    AussieDoug Full Time Elf
    Dec 1, 2012
    375
    0
    I'd say it would have been faulty. Good thing you were out there when it happened.
  3. Steve22537
    Steve22537 Full Time Elf
    Dec 13, 2010
    258
    8
    Harrisdale, WA
    Good thing you had a beefy power supply, many amps makes lots of smoke.
  4. OP
    OP
    elnino
    Aug 1, 2014
    137
    0
    I had it hooked to an arduino and that fried too. Only from over current tho, not due to error. This particular string was only 25 pixels so it was running from a wall wart in the standard jack on the Arduino. Obviously the arduino is not designed to take several amps on its tiny tracks. All good now tho, just makes me nervous about the other 99 pixels.
  5. scamper
    scamper Senior Elf
    Jan 5, 2014
    982
    129
    collie
    That right there is a good reason to fuse your outputs :-\
