Pixel Clips
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by bhamze, Jan 2, 2015.
  1. bhamze
    bhamze New Elf
    Jan 2, 2014
    30
    0
    Hello all,
    I'm currently developing several RGB/Pixel clips and I need your help. I've created a site and kindly ask for your participation by completing the product survey. This survey will help determine item specifics including model numbers, quantities, and pricing. The more feedback received the better the outcome. Please feel free to leave comments or suggestions on future products. To help spread the word, please share link or make recommendations for other channels. I thank you for your support.
    Bill
    lightingclips.com
  2. lizardking
    lizardking IT IS STILL ALL BENS FAULT
    Dec 26, 2014
    416
    0
    Gold Coast
    hi Bill mate what an idea what a great idea i like the pipe ones i was looking at 20 mm od conduit for my mega tree so i would be looking at 800 just for my tree but bear in mind zip ties are 1c each and also i am looking at mounting straight 20 mm pvc on the uprights on my pergola post so maybe another 400 so if you could get close to 3 or 4 c each in bulk i would definitely look at buying them plus 2016 i will do rooflines and more so i would buy more next year too but if you could get close to the price i would consider buying at least 2000 at a time to suit the 2801 12 mm pixels
  3. gnatman
    gnatman New Elf
    Dec 4, 2014
    18
    0
    Mesa Arizona
    How about some that don't need to go on a pipe but rather the eve of a house. I'd love to print these on a 3d printer. I love 3d work.
  4. Superman
    Superman I Have C.L.A.P and its very infectious Global Moderator
    May 29, 2010
    1,709
    41
    Ipswich-QLD
    going off the website they look like they have plans for a few different types including facia..
    I have sent an email to get some samples to see if they are usable on our common conduit.
  5. prof
    prof Apprentice Elf Generous Elf
    May 26, 2010
    80
    0
    Bundanoon
    For the pipe clip sized models, a quick search shows that 1/2" schedule 40/80 has a nominal OD of 0.840" (or 21.336mm). For an Aus. equivalent the IPLEX brand DN15 (PN18) PVC-U pressure pipe also has the 21.3 mm nominal OD. Different brands may have different naming conventions so a quick visit to you local plumbing supply or hardware store should get you sorted. I think both sized clips are going to be too loose a fit for either 16mm or 20mm conduits.
    prof
  6. mborg10
    mborg10 Michael Borg
    Dec 28, 2011
    1,446
    0
    claremont meadows
    I'd be interested in ones that clip to the gutter, but will prob use the conduit ones as well.
  7. tooms
    tooms Full Time Elf
    Jan 2, 2015
    120
    21
    Kalgoorlie
    +1 for a gutter clip, I'm currently researching the best way to attach pixels to the gutter and haven't found anything simple and quick yet.
  8. Habbosrus
    Habbosrus Back again
    Dec 5, 2012
    757
    17
    Swansea, NSW
    I made a suggestion on the survey that a slight modification could see them used for holding strip to conduit as well. I cable tied my led strip to conduit for my 2d ray tree. I actually made some clips from conduit just the other day. I used conduit, cut it into 10mm pieces and cut a piece out of it. It looked a little messy as it was all done by hand, but worked well. The clips just look like a "C" and slip over the strip and conduit. These look much nicer than my attempt and could serve multiple purposes.
  9. lizardking
    Dec 26, 2014
    416
    0
    Gold Coast
    wondering how these clips are going havent heard if they are coming along
  10. OP
    OP
    bhamze
    bhamze New Elf
    Jan 2, 2014
    30
    0
    Thanks for your interest. I've selected a tooling/plastic manufacturer and tooling will be launched soon. I plan on sending an update sometime next week.
  11. zman
    zman Full Time Elf
    Jun 8, 2010
    100
    1
    Woodinville, WA
    Whatever happened to this effort? ANy updates?
  12. bluzervic
    bluzervic 65,768 Channels, 185 Universes
    Dec 31, 2011
    533
    27
    Fremont, Calif.
  13. OP
    OP
    bhamze
    bhamze New Elf
    Jan 2, 2014
    30
    0
    Im working on a new site and it will be up soon. Clips have been tested and approved for production. I will post updates on my FB page, link below. Thanks for your support!
    Bill
    https://m.facebook.com/RGBetc
  14. bluzervic
    Dec 31, 2011
    533
    27
    Fremont, Calif.
    Will there be PVC ones for round pixels as well ?
    Definitely keep me posted as I want a good sized QTY.
    Do not really follow Facebook too much.
    -Blu
  15. OP
    OP
    bhamze
    bhamze New Elf
    Jan 2, 2014
    30
    0
    They fit round or square nodes via an insert. Check link below.
    https://youtu.be/JFz8G4iGne8
