Pixel mounting strips
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by Merry McSnowballs, Jan 19, 2018.
  1. Merry McSnowballs
    Merry McSnowballs New Elf
    Jan 8, 2018
    21
    11
    Does any one know where to get the pixel mounting strips in Australia. All the US sites I’ve looked at don’t ship to Aus. Any advice would be greatly appreciated.
    Ben
  2. darylc
    darylc 404 darylc not found Global Moderator Generous Elf
    Dec 8, 2012
    552
    154
    @TByrne imports from Boscoyo to resell, Boscoyo also ship directly to Australia
    Troy ELD likes this.
  3. OP
    OP
    Merry McSnowballs
    Jan 8, 2018
    21
    11
    Thanks darylc.
  4. Matthew Thompson
    Matthew Thompson Santa's Little Helpers
    Nov 2, 2011
    62
    17
    Baldivis
    There is a group buy for Boscoyo on one other page too to save on freight. I found a place in WA that would make the strips however the cost is cheaper with freight from Boscoyo.
  5. Troy ELD
    Troy ELD Full Time Elf Generous Elf
    Nov 26, 2011
    253
    96
    Central Coast
    Unfortunately the freight is the same with strips. Weight is the issue
  6. Ledmechanic
    Ledmechanic New Elf
    Dec 28, 2017
    5
    0
    Bunnings this is what I use
    [​IMG]
  7. Ledmechanic
    Ledmechanic New Elf
    Dec 28, 2017
    5
    0
    It’s called strapping brace .8mm thick 25mm wide 30m roll 21.00 you just have to redrill holes to suit 12mm or 9mm it’s available in stainless with 1inch increments the galv stuff is approx 2inch increments
  8. Ledmechanic
    Ledmechanic New Elf
    Dec 28, 2017
    5
    0
  9. SantaClaws
    SantaClaws New Elf
    Sep 17, 2016
    45
    3
    Gold Coast
    I found these strips at Bunnings.
    They are for plaster walls/corners and will hold pixels great.
    Just insert at the desired separation.
    They're cheap, and come in 3m lengths for about $5.
    I used tin-snips to cut them in half lengthwise.
