Pixel Strip Leaping Arches
Discussion in 'Leaping Arches, Driveway Arches & RGB Arches' started by koolantz, Nov 15, 2015.
  1. koolantz
    koolantz New Elf
    Nov 21, 2010
    6
    0
    Townsville
    I knocked up 4 pixel arches out this weekend out of some spare 2812B strip I had.
    Half a roll of strip per arch (2.5m or 75 Pixels), 2.6m of 20mm conduit and 38 cable ties per arch!
    Drilled some holes near the ends of the conduit and used builders string to pull the ends together to make a "Bow".
    Going to borrow an idea and use pieces of reo bar hammered into the ground to slot into the ends of the conduit to hold them up.
    Some photos of the construction:
    A video of the result here:
    View: https://vimeo.com/145766171
  2. mellowcouple
    mellowcouple Full Time Elf
    Dec 18, 2011
    285
    15
    Whyalla
    Good job the look great. Nice and simple to make to.
  3. rjt65
    rjt65 New Elf
    Mar 27, 2015
    11
    0
    Hi
    Was wanting to build arches, yours are great, but how did you get the leaping effect with the strips. Looks like one length of strip per arch. I have 12v 3528 led strip.
  4. dale82
    dale82 Senior Elf
    Nov 19, 2010
    568
    0
    Kingaroy
    Rio rods hammered into the ground works a treat. I did all my arches like that
  5. i13
    i13 Senior Elf
    Jul 5, 2013
    804
    21
    This is because the arches are made with pixel strips. I don't know of any pixel strips that use the 3528 LEDs so it sounds as though you have strips that can't do this. You probably have single colour dumb strips which aren't pixels. You and I had a relevant discussion back in March and I can resend the messages if you haven't kept them.
  6. rjt65
    rjt65 New Elf
    Mar 27, 2015
    11
    0
    Hi
    I remember that conversation, still have it. Refers to needing a pixel driver or something like that.
    Thanks for the reply
  7. OzAz
    OzAz Senior Elf Generous Elf
    Dec 29, 2015
    540
    164
    Newcastle
    That's what I'm planning to do for mine, glad to know it works. I'm using 15mm PVC Pipe (found it easier to bend than 20mm), was thinking of having a 3rd longer piece of reo cable tied to middle of arch for support.
    Is there a formula somewhere for how much to bend the pipe (I'm using 3m lengths) or just what feels best?
    Do people put the pixel strips on the top of the pipe or the side facing out?
  8. fasteddy
    Apr 26, 2010
    6,635
    63
    It is important to ensure you have a bit of a fold in the strip between each cable tie mount due to the uneven bend of the strip as strip is normally made for a straight line, you can notice in the video that this is what was done. So best to first bend the conduit before mounting the strip because if you bend it with the strip mounted then you run the risk of damaging the strip, The folds wont be noticed when the lights are running.
    This is a very quick and easy way to make a very impactful element for your display
  9. Homer2014
    Homer2014 Apprentice Elf
    Dec 28, 2015
    52
    3
    Broome
    Did you use anything to soften the conduit to get a nice rounded shape ?. Tried making a couple today and just end up egg shaped....
  10. BundyRoy
    BundyRoy Dedicated Elf
    Apr 9, 2014
    1,026
    9
    I just pulled the ends in on mine till it looked about right. I used 4m conduit with 3m of strip on the conduit so I had a bit with no lights on each end of the conduit. Mine are laid down on the roof though so I can overlap them to get rid of the gap.
    Don't put a heat gun anywhere near electrical conduit. It goes really soft and bends. Tried to be lazy and fix a break in the strip without taking it off the conduit once. Lets just say one of my arches has a unique bend now.
  11. Homer2014
    Dec 28, 2015
    52
    3
    Broome
    Cheers, I tried just pulling the conduit together but didn't look quite right. I'll have another go this week.
    Made 3 small arches yesterday using the front wheel of my bike to get the shape....
    [​IMG]
  12. BundyRoy
    Apr 9, 2014
    1,026
    9
    I seem to remember (it's been a couple of years now) that I left the conduit longer to get a better curve shape. I think it was harder to get a decent curve with a shorter length.
    The arch you made looks great. How did you get it to hold the shape when you removed the wheel.
  13. bjpc2716
    bjpc2716 who dares win
    Jul 11, 2012
    685
    12
    melbourne
    great job
  14. Homer2014
    Dec 28, 2015
    52
    3
    Broome
    G'day
    I left the conduit cable tied to the wheel and filled with tap water a couple of times to cool off. Was 110cm length of 20mm conduit with 1m of strip.
