Pixels on the roof
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by deblen, Mar 23, 2018.
  1. deblen
    deblen Apprentice Elf
    Mar 20, 2011
    92
    6
    I am thinking of covering my roof in pixels
    The strings would go from top to bottom.
    What spacing would the pixels would one recommend, that would give a even view from the street.
    Ray,s strings are 100 per 5 metres, this would be a quite expensive, so to reduce the cost, get them customer spaced.
    I was thinking of 12v square nodes.
    The result to give a matrix effect for the whole roof, but at a reduced cost.
    Just an idea, depends on cost of nodes.
    Thanks. Deblen
  2. ChristmasInKaralee
    ChristmasInKaralee Senior Elf
    Feb 15, 2014
    502
    103
    Karalee
    Rays standard 100 pixel strings are 10m, not 5m as they are 100mm spacing.
    There the ones I use and the spacing is fine, I wouldn’t go any less.
  3. Dave_Szoka
    Dave_Szoka New Elf
    Jan 1, 2014
    35
    23
    Hobart
    Here is my roof line... 90mm spacing
    Boof63 and ElSalZi like this.
  4. OP
    OP
    deblen
    Mar 20, 2011
    92
    6
    Thanks Szoka and Karalee,
    I want to be able to cover the while roof, top to bottom, side to side.
    This would require a lot of strips.
    Currently have LEDs, which give a great effect, 4 colurs individual strings twisted together, unfortunately they are about Te end of their life.
    To reduce the cost of pixels, is to work out spacing, but be able to have an effect.
    Thanks Deblen
  5. djgra79
    djgra79 Senior Elf Generous Elf
    Dec 27, 2011
    942
    211
    Cranbourne West
    Roosta likes this.
  6. OP
    OP
    deblen
    Mar 20, 2011
    92
    6
    Thanks djgra79,
    Looks very neat and tidy, now will need to get the tape measure out.
  7. Barnabybear
    Barnabybear New Elf
    Mar 30, 2012
    26
    2
    UK
    Hi, roof or roof line?
  8. OP
    OP
    deblen
    Mar 20, 2011
    92
    6
    Hi, Barnaby, I would like to cover the whole roof.
    Deblen
  9. Jimbo
    Jimbo Full Time Elf
    Feb 27, 2014
    129
    16
    Tfpsound and Boof63 like this.
  10. OP
    OP
    deblen
    Mar 20, 2011
    92
    6
    Hi Jimbo,
    Very nice.
    Thanks for sharing.
    Are you able to give some insight to Controller used, power injection, and wiring all the strips.
    Deblen
  11. Jimbo
    Jimbo Full Time Elf
    Feb 27, 2014
    129
    16
    Sure,
    Use falcon 3. Total of about 20 power injection points. Using ws2811 pixel strip, 10 pixels per metre. There is about 175 m in total, all mounted to conduit which clip into conduit clips mounted on the roof.
    The power injection is roughly every second strip on Longer runs, but can get away with it being every 10-15m.
    The falcon controller is set to 60%. In total uses 3 12v power supplies.
    Wiring is all 3 pin waterproof plugs, with separate fuse box of 5amps on all power injections.
  12. OP
    OP
    deblen
    Mar 20, 2011
    92
    6
    Hi Jimbo,
    Thanks, will give me a good idea on what I need .
    Deblen
