I have pixel nodes on outline of my house there are 6 nodes in middle of the string that are not lighting could the nodes be bad when I have had a bad node in the past every thing after the nodes was out
It does sound odd that the whole string isn't working after the damaged pixel/s. It is possible that data and power could pass threw like a null pixel. Before you go cutting them out are you able to switch connections with another working string, just to make sure its not an issue at a controller level.
I would confirm that they are configured correctly first because if you have a section out and it still works past that section then a good chance is that it is the configuration rather than a faulty pixel. Try and connect another string/strip to the output to confirm before removing and replacing
