Pixels Strips on Gutters
Discussion in 'How is your display put together...' started by Cabrinha, Apr 24, 2017.
  1. Cabrinha
    Cabrinha New Elf
    Jan 3, 2015
    10
    0
    New South Wales
    Hi All,
    I was wondering if I could get a bit more detail on how everyone mounts strips to their gutters in particular how you negotiate corners with ws2811 5m roll 30leds/m pixel strip. I have a gutter line like below
    _______________
    5.1m | ___________3.6m
    3.3m |_______|0.8m
    3.5m
    Option 1: Do you cut the 5m strip to fit the straight sections of the gutter and then solder on pigtails and connect each section?
    Option 2: Keep the 5m length intact and bend it around the 90 degree corners and then connect 5m lengths using pigtails
    Option 3: Cut the strip at the corners and solder in a short section of wire to make it more flexible around corners
    Thanks in advance
  2. fasteddy
    Apr 26, 2010
    6,592
    51
    I found the best method was to attach the strip to 25mm electrical conduit to keep it nice and straight and easy to handle and then cut to suit each straight length of your gutter, then fit a plug in between each section. This then makes it easy to put up and to pull down and store. So option 1
  3. djgra79
    djgra79 My name is Graham & I love flashing lights! Generous Elf
    Dec 27, 2011
    985
    232
    Cranbourne West
    I do option 1 similar to what Eddy described. My lengths are no longer than 2m for easier storage, all with 3pin connector plugs.
    However, to negotiate corners (of which I only have 2 for gutters) I just have the strip corner around naturally, but then supported by the conduit.
    You can sort of see in first few minutes of my video here: https://youtu.be/sK5LGq8Wd7c
  4. Dave_Szoka
    Dave_Szoka New Elf
    Jan 1, 2014
    39
    28
    Hobart
  5. Roosta
    Roosta Full Time Elf
    Dec 8, 2015
    174
    63
    Hi,
    I have done both option 1 and 2 and had good results.. Which method is best well thats bend dependant..
    25mm conduit is a great way of doing nice straight lines and curves with strip..
    Here is a distance pic on option 1 used on gutter to roof ridge line..
    [​IMG]
    Here is a pic of option 2 on the garden bed and candy canes..
    [​IMG]
    [​IMG]
    Hope that helps..
    Cheers,
    Nik
  6. OP
    OP
    Cabrinha
    Cabrinha New Elf
    Jan 3, 2015
    10
    0
    New South Wales
    Thanks everyone for the fast responses including the pics and videos. I intend on mounting it to 25mm conduit but just could not get my head around what to do with the corners of the gutter. I think for ease of mounting, storage and a place for power injection I will cut the strips to fit the straight sections and mount pigtails at each end.
  7. MacArthur St Light Fusion
    MacArthur St Light Fusion Apprentice Elf Generous Elf
    Dec 28, 2015
    97
    18
    Moranbah
    Bradbaker, Mischka and Boof63 like this.
  8. Jamie
    Jamie Lighting up the night.
    Dec 16, 2010
    387
    1
    Warwick
    No potential spanner....works great. Been using for a few years now with no issues.
    Mischka likes this.
  9. MacArthur St Light Fusion
    Dec 28, 2015
    97
    18
    Moranbah
    How do you attach yours Jamie?? I've been looking at some options, but am hoping not to use screws or anything that puts holes in my new weatherboards this year???
  10. fasteddy
    Apr 26, 2010
    6,592
    51
    The way I mounted my conduit was to just buy a roll of heavy duty tie wire from Bunnings and then make up gutter hooks that hold the conduit in place, also makes it quick to remove for any repairs or when you are pulling down the display. Ive also used it for window frames making hooks that can hook onto the window frame and hold the conduit in place.
    But being rigid you may be able to take the same approach for conduit and use heavy duty tie wire to cut and make steel hooks that will be able to hold your strip in place
  11. videoman3857
    videoman3857 Full Time Elf
    Apr 21, 2016
    327
    75
    Glass House Mountains
    I use only LED strings for around my place. - they just twinkle.
    I used 20 mm conduit from Haymans Electrical supplies and conduit saddles from Bunnings directly under the gutter. I painted them the same colour as the facia
    I drilled tapered holes in the conduit at 80mm intervals so the led sits snug in the conduit and
    I routed a groove in the saddle to allow the wires to run by.
    The cable runs behind the conduit and in front the fascia board and is not in the weather
    Corners are pig-tailed and are tucked behind the gutter drops.
    These lights are pretty well out of the weather and the suns direct uv rays and have been left up permanently
    for three years now.
    20 mm conduit is not as rigid as 25 mm, but 25 mm mounted on the clips protruded out further than
    I wanted so I went the 20 mm and just used more saddles for more stability.
    Pig-tails on the corners was the only option for me as it was:
    • too difficult to try and solder everything up on site
    • made it easy to hide the wires behind gutter drops
    • made it easier to place the conduit on each face of the house.
    Ben F likes this.
  12. NTKing(Brad)
    NTKing(Brad) Full Time Elf
    Dec 28, 2016
    329
    103
    Albany Creek
    Do you have some close up photos? Struggling to picture it.
  13. videoman3857
    Apr 21, 2016
    327
    75
    Not at the moment, but I will take some as soon as my son returns my camera. Stay tuned.
    NTKing(Brad) likes this.
  14. fasteddy
    Apr 26, 2010
    6,592
    51
    The method I have used now is to have my lights permanently mounted to the bottom of the gutter inside diffused aluminium channel, this way it looks neat and is functional all year around as architectural lighting
    Ben F and NTKing(Brad) like this.
  15. NTKing(Brad)
    Dec 28, 2016
    329
    103
    Albany Creek
    Thank you. I am also about to install gutter lights and debating about using the conduit method direct to the gutter, or nailing the lights to the eaves directly behind the facia.
