Introducing our PixLite 16 controller:
This pixel controller is like many of the other ones you will have seen, with the following major distinctions:
-Currently the most powerful and best value per pixel controller on the market
-Control up to 32 universes of sACN with up to 340 pixels on each of the 16 outputs
-Simple windows application automatically lists all controllers on the network (no need to remember IPs)
-Configuration happens through this application with an intuitive user interface rather than through a web browser
-Out of the box will connect to any network with a router immediately - or defaulting straight to it's factory IP if no router exists
-Has a simple "auto string addressing" feature if you are running all strings the same length or..
-Advanced settings allow individual string lengths, universe/channel address, reversing, zig zag, null pixels
-Simple gamma correction (on compatible chips)
-Very simple firmware upgrade procedure for making use of our regular feature upgrades
Currently supports the following chips:
-TLS3001
-SM16716
-WS2801
-WS2811/TM1804
-LPD6803
-MBI6020
New chip support can be added on demand.
The controller comes in a "DIY" form (PCB only, pluggable screw terminals for wiring your own lights), as well as a "Plug & Play" form. The P&P controller is designed for simple setup where our high quality light strings plug directly into a weatherproof control box with controller, power supply and pigtails all ready to go.
-TLS3001
-SM16716
-WS2801
-WS2811/TM1804
-LPD6803
-MBI6020
