I have two things I am trying to work out with my Pixlite4.1) I cannot seem to update the firmware. I'm using a Mac. I downloaded the latest hex file (1.4.7) and using the advatek assistant in the misc tab, clicked to update and browsed to where the new hex file is. But every time I click update, the program pauses and then eventually comes up with a time out error. The lights on the Pixlite flash between red and green when i hit update but it never seems to actually complete the update.2) Second problem is getting my channels right for my arches in the PixLite 4. Now I might be expecting to do something unreasonable. I know the pixlite 4 can do up to 4 universes per output. I want to do 2 universes per output at this stage.I have four sets of arches (3 arches per set) and each set takes up 435 channels. So I want to use only two of the outputs of the Pixlite4 for these. So each of the two outputs will run two sets of arches (total 870 pixels per output) and therefore use most of two universes per output.In Xlights I have each set of arches using one universe each (Universes 33,34,35 and 36)[font=verdana, arial, helvetica, sans-serif]So , for example, I'm not sure how to setup output 1 so that it will work across the first two sets of arches (universes 33 and 34). I know that the first arch set will use 435 channels of the 510 available for universe 33 but there will be 75 channels left over unused before the next set of three arches (using universe 34) starts. How to I tell the Pixlite4 to ignore the last 75 channels of universe 33 and then go straight to universe 34 to light up the next set of arches. I have tried setting this up but keep getting the first 25 pixels (75 channels) of the second set of arches not lit up and I'm assuming that is due to the unused 75 channels (25 pixels) left over from universe 33.I realise I can get all four sets working if I use all four of the Pixlite 4 's outputs (one set of arches per output) but was hoping to take advantage of the fact that the pixlite4 can give multiple universes per output.
[font=verdana, arial, helvetica, sans-serif]I guess I'm used to the P2 where each of the two outputs has 4 slots available for inputting the individual universe data whereas the Pixlite4 has only one slot per output and I don't know how to tell it how to use only 435 channels of each universe of the two universes for that output.[/font]Hope I have explained it ok, sorry if I haven't [/font]
