Pixlite16 LR
Goliath
Gracemere
Just want to say what a bloody brilliant piece of hardware this is!
This is my first year with pixels, and I was fearful about buying multiple controller boards to distribute over various parts of the yard and roof. One Pixlite16 LR, and 8 remote boards ( I'll probably wind up only using 5, and none of those are maxed out) and the neighbours are reaching for their sunglasses :)
plasmadrive
Elk Grove, CA
I bought one.. tried it.. loved it.. bought 2 more. I have been using pixel extenders.. so this solves two issues at one time. Service from Luke is very good!
There are only two things I wish would change.. One is a software change to allow for the "test" mode to happen from the computer. I mount mine under the 2nd story eves so it is unusable for me.
The other is a cable limitation. If you use it in a condensed mode you need to supply a common V- connection between power supplies, if you use separate supplies for the main board and the lights. Not really sure what to do about it other than use shielded Cat 5 cable and connect the shield as V-. Other than that you can use a separate wire to connect them.. You don't always have to connect the V- from each supply together.. but you need to pay attention to RS485 wiring structure so you don't exceed the differential voltage from V- between supplies.
darylc
404 darylc not found
My understanding is that you can get around this by using the isolated receivers.
https://www.advateklights.com/shop/mantis-pixel-mapping/45-pixlite-long-range-isolated-receiver.html
Daryl
BundyRoy
I see the controller can handle 340 pixels/output. So does the one receiver handle 340 pixels as well or do you need multiple receivers per output. The other thing that was a little confusing on the website was can this controller handle multiple pixel types together. (eg ws2811 on one output and another type on the next output).
The receiver has no "smarts" in it and it will receive however many channels are pumped at it.
Unless there's been a change very recently all pixlites have the same pixel type on all outputs.
darylc
One receiver can do 2 outputs of 4 wire pixels, or 4 outputs of 3 wire pixels, So either 2x340 or 4 x 340 pixels per receiver.
If you do 4 outputs then you can only use 4 receivers, not 8.
