Helty
Hey guy,
Where do you guys get your 2 core power injection cable from and your heat tube?
Thanks guys
Thanks guys
Extension Cables: (Try not to go past 8 meter extension cables. You normally degrade signal after 6 meters. This is a complete variable all depends on your setup.)
https://www.aliexpress.com/store/pr...l?spm=2114.12010612.8148356.53.5dd08124tDlm1D.
F-amps are good just a little tricky to source here in AUS. you can get the same result with one of Alans null buffers which is the same thing
http://www.hansonelectronics.com.au/?s=null&post_type=product
What about those Falcon F-amp signal boosters ?
