msherratt
Hi. I am wondering if anyone can help me.
I have my whole display working except for a few stubborn elements. I have two windows both the same size both wired the same with data, +Ve and -ve wired into the start of 30/10 strip and +Ve and -Ve at the end of the strip to a fuse hub and ground block for power infusion.
When I run a test of any colour one window does as it should but the other flashes white for a split second and then doesn't light. The fuse is intact. If I just run the back end power injection and disconnect the cable to the controller it works with full white so I don't think I have a bad circuit.
Is there something I should be checking for?
