tmarshal61
- Oct 14, 2013
I have several 5V WS2812B strips to mount on my roof line. Yesterday, I mounted two of them with 142 pixels each. Prior to installation, I had tested everything thoroughly and everything worked with no problems. I did not get around to firing them up until today and now they are acting erratically. I have some sections that do not light up or light up randomly. and I have random color flickering. It may pause for a bit then the sequence starts running partially with some more random flickering.
What is the most likely issue? I am running a pretty good distance, maybe 40 feet from the controller. Prior to installation, I tested to see how far I could go without a null pixel and I ran 90 feet with no issues. Still, I decided to go with a null pixel at the 20 ft point just to be safe. I might add that last night and much of the day, it has been raining although, it has not rained in about 8 hours or so.I am running two 12 AWG power wires, I have numerous power injection points, and the pixels light up very bright white with no pink hue, (of course with some pretty major color flickering going on), so I am pretty sure voltage drop is not an issue.
Should I try adding more null pixels or could there be a grounding issue going on. Could it be something else? My gut feeling is that I need more null pixels but, I don't understand why I could get 90 ft with no power injection and now I am having issues at 20 ft. What is the most likely cause of these types of symptoms? It is a real pain to get into the attic crawl space where the wiring is run. I hate to go rip out the the wiring to install more null pixels if that is not the likely cause.
This is my first attempt to put on a display so, I am pretty inexperienced. I appreciate any suggestions.
