Random Flashing on Unuses/Off Strips
tbateson
I'm testing a new AlphaPix 16 – E1.31 along with Smart Pixel RGB LED - 30 LEDs/m 10 Pixels – 12v strips
Problem: Pixels on other universes are randomly flashing, even when are not programmed. Also, when NO sequences running and all of the software is turned off they are still randomly flashing. Any thoughts?
I have these on a dedicated network using a separate nic card.
ShellNZ
Karaka, Auckland, NZ
Could be lack of power (do you have enough power to run all those pixels)
Could be the network cable (try using another cable).
Could be the distance from controller to the offending pixels.
Could be (but not likely) interference.
I would hope that it's not the case but it could be a code bug as the alphapix is a cheap chinese knockoff of the Pixlite 16.
tbateson
I have the controller next to the computer - short run there. The strips are connect directly to the controller's pigtails - short run there too.
A couple days ago I did test one strip for distance and was able to reach 40' (12.2m) on these HolidayCoro cables before any issues, so I think we can rule them out at 2' (.6m). I didn't notice any randomness at that time, but I was more looking at the light quality and distance.
jerrymac
Quitman GA
Go to the LOR board. There is a lengthily discussion re: this David at Holiday Coro is working on a resolution.
tbateson
Could you post a link to it? As I cannot find that discussion.
tbateson
Thanks for the link.
From that forum, it seems HolidayCoro is working for a Firmware fix. However it only occurs while the LOR Listener is running, so it makes one wonder where the problem is being caused.
