Raspberry pi connection to FM transmitter
aplant92
Melbourne
I'm planning on using a Pi to run my show using FPP, and I'm just wondering how the setup should look with an FM transmitter (I bought one from EDM design which seemed highly regarded in the auschristmaslighting guide PDF).
Can these be directly connected to the Pi, with the Pi outputting audio to it? Is this how it's normally done?
Tried searching here and the Falcon Christmas forums but couldn't see anything that seemed to answer this.
djgra79
Cranbourne West
Yes the simple setup would be to use a 3.5mm plug to RCA splitter cable such as: https://www.ebay.com.au/p/Audio-AUX...er-CAB/2229234572?iid=282675462228&opts=opick
Some people say the audio direct from the Pi isn't the best, so something like this could assist: http://www.smartaleclights.com/shop/index.php?route=product/product&product_id=81
If you want to go advanced, you caould get a little USB mixer which will allow manual volume control and possible EQ. You could then split your audio out to both the FM transmitter and directly to some speakers. I think many just tune into the broadcast however.
scamper
collie
Yep, I used the standard output from the Pi for the first year, but it was a pain and was intermittently distorted, then I went to the little usb sound card like the one on smartalec's site.
It was much better!
drakky
It was much better!
it says no drivers needed for those sound card on Smartalec's site however if you plug it into the pi it doesn't work, so maybe some sort of driver is needed?
Ellis
Naughty Elf
Gold Coast
You need to change setting in FPP to enable sound from USB device.
drakky
sorry I know nil about the Pi I just loaded FPP and it all worked , so I don't know how to change the setting , where will I find that info please?
Ellis
Naughty Elf
Gold Coast
In FPP... in Status/Control select FPP settings, change Audio Output Device to USB (with USB device connected to PI)
drakky
wow didn't realize it's built into FPP thanks Ellis works now much clearer, awesome
