RGB Mini Tree Mini Forest Part 1
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by nutz4lights, Aug 4, 2014.
  1. nutz4lights
    nutz4lights Full Time Elf
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    Hey all,
    I have always run mini trees in my display... back in 2006-2008 time frame, that consisted of around a dozen of the 1 meter (3 foot) green wire easels wrapped with a couple hundred white incandescent lights... around 2009, I got a heck of a deal on unlit evergreen-looking mini trees from Target (they were 90% off so I wound up with somewhere around 30 of the 1 meter tall versions and at least 50 of the 60-ish cm (24") versions. I added 300 white incandescent mini lights to the 1 meter versions and around 150 white incandescent lights to the 60cm trees and was very happy with those until last year... last year was my big jump into RGB, adding somewhere around 7000 pixels and probably another 2000 dumb nodes. I didn't have it in my budget to do the 48 mini trees (16 x 1 meter and 32 x 60cm) so I put them out there with their white incandescent lights.... and I hated it so much, they didn't even get programmed into the display. :p I knew with that, that I needed to convert them to RGB this year and elected to go with pixels instead of dumb nodes.
    Here is a video showing the 16 x 1 meter trees in the arrangement they will be in (which is at the base of my 6 meter pixel megatree)... I elected to go with just 50 ws2811 pixels on the trees and happy with the outcome. I went with 50 pixels mostly due to the way I want to control all of these. I plan on using 8 outputs from the PixLite16 controller from Advatek to control these 16 trees (2 trees per output)... I plan on controlling the 32 smaller mini trees with the other 8 outputs from the PixLite16 controller (4 trees per output).
    https://vimeo.com/102477914
    the 32 x 60cm trees are next... first step is stripping all of the old mini lights off...
    Enjoy.
  2. AussieDoug
    AussieDoug Full Time Elf
    Dec 1, 2012
    375
    0
    They look great, just wondering why you are only doing 2 tree's per output when each output could run 6?
    Each output can run 340 pixels is all.
  3. OP
    OP
    nutz4lights
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    Definitely a good point. Basically, 16 of the 1 meter trees and 32 of the 60cm trees is what (I feel) looks good in that location of the display. I had to put a controller there and decided to go with the PixLite16 due to the 16 outputs and the fact that I was using 16 and 32 of each tree type (even multiples). I <currently!> don't have anything else to put in that part of the display, which I'm sure will change! The PixLite16 controller will go on the megatree pole with two p12s controllers (they control the 48 megatree strings). I guess I've never been big into pushing controllers to their max.
    So there is some logic to my selection, but it is definitely fuzzy logic... ;)
  4. coopz05
    coopz05 Apprentice Elf
    Nov 18, 2011
    61
    0
    Hallett Cove
    Do you have a trick for keeping them perfectly in place?
    I have the same trees but are having trouble
  5. OP
    OP
    nutz4lights
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    A whole lotta zip ties! I started off thinking that we would just use 5 - 10 per tree and ended up putting a zip tie on almost every pixel... Sounds horrible but it only took around 15-20 minutes per tree...
  6. algerdes
    algerdes Al Gerdes
    Nov 29, 2012
    129
    21
    Lebanon, Illinois
    The trees look great. The tree-to-tree chases are working wonderfully.
    I'm curious if you have tried bottom-to-top or top-to-bottom fills?
  7. OP
    OP
    nutz4lights
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    Thank you! I wired them all from bottom to top, so I definitely plan to figure out the bottom up fills in lsp...
  8. sck1ng
    sck1ng Apprentice Elf
    Oct 23, 2013
    77
    0
    Thank you for inspiring me :) I ordered my lights for the season from Ray and added lights to make 8 of these.. Now I just need to find some cheaper 36" trees..
  9. OP
    OP
    nutz4lights
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    In the States, it has been tough the last couple of years to find good deals on decent looking trees. I wish you luck!
