chris19681986
- Jan 2, 2021
So I posted on here of which controller should I purchase and got some excellent feedback. Instead of the F4 I purchased the F16v3 thinking extra ports etc would be the way to go. Now I am not so sure since I have watched more setup videos and now assume I need a second control card by the arches plus a second power supply. CORRECT??? I have marked the location inside garage where I will have the control card/ power supply mounted. that will give me easy access to connect the roof line lights. from that location its approximately 35 ft out to the arches from garage plus another 8ft up to power location.. I will be running a cat6 cable from basement where router is at to the garage power location. So out to the arches, could i run a ethernet from the f16 for data along with power and ground for the lights? I have a roll of 14ga wire i could run out there from the garage. All this would be in conduit. That I am assuming would eliminate the control card and a second power supply could be mounted next to the first? roof line are 2811 5v strings and arches will have either 5 or 12v led strips. I have a 5v 300s 60 amp power supply right now. More than likely run it all at 30%.
