set up less lights than in string
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by OzAz, Apr 23, 2017.
  1. OzAz
    OzAz Senior Elf Generous Elf
    Dec 29, 2015
    558
    173
    Newcastle
    Hi Gurus, I have a dilemma.
    Have 4 strands of 50 pixels, that came pre-pigtailed on each end.
    Want to connect 2 strands together off each of 2 ports of controller. - I've attached a rough drawing.
    BUT want to use only 48 pixels in each strand (Prop has only 48). being lazy and don't want to cut off last 2 pixels of each string as I need the pigtail at the end of the first 2 strings anyway.
    Question - how do I set this up in xlights and my controller?
    I can easily setup so last 2 lights of second strings don't light up, but I can't work out how to stop last 2 lights of 1st strings lighting up.
    Any suggestions?
  2. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    452
    79
    Kellyville, NSW
    >previousmodel:7 will skip 2 rgb nodes and start after that.
    But basically you just need to set the start channel correctly.
  3. fasteddy
    Apr 26, 2010
    6,636
    66
    Depending on the controller you use then you could use Null pixels as an option as well. but this wont work with every controller, only with controllers that support Null pixels
  4. OP
    OP
    OzAz
    Dec 29, 2015
    558
    173
    Newcastle
    Thanks Keith that worked
    Though for practical physical reasons I would have preferred last 2 leds to be off. But will work with what works.
    Thanks Eddy, I did try that but my controller will only do Null pixels at end of all strings.
  5. keithsw1111
    Oct 11, 2012
    452
    79
    Kellyville, NSW
    The LEDs should be off if you have it setup right.
