Sizing pictures for LSP visualizer
oldmanfathertime1000
Computers, music, audio, video, electronics
Lake Arthur, Louisiana
Sizing pictures for LSP:
Any size picture can be brought into LSP correctly if the Height/Width ratio is right.
Most every one is having a squashing of the picture when LSP loads it up.
If you make the picture as (Height=2 & Width =1.2) Ratio, you will have the correctly ratio & aspect for LSP
to load up the picture without squashing it.
Examples:
2 in x 1.2 in
20 in x 10.2 in
2cm x 1.2cm
20cm x 10.2cm
(any ratio that = 2x1.2)
The reason why LSP is not very responsive to wide screen pictures is due to how LSP maps the elements into a visualizer so the picture must follow a predetermined ratio or else it will sqash the picture because the mapping area is defined by LSP
As for Shells picture she is trying to use 2711 x 757 so a very wide picture. I found that with wide pictures like this all I do is put the picture into a word document and then just use the screen snipping tool to create a jpg and then I snip the picture and add to the top and bottom in my selection so the dimensions of the picture are closer to a traditional picture.
