Soldering crimp connectors
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by damo1271, Nov 22, 2014.
  1. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    197
    5
    Adelaide
    After just finishing making some power cables I was wondering...
    Does anyone else solder their crimp connectors, or is it just me that does this?
  2. David_AVD
    Jun 12, 2010
    3,951
    263
    I used to a long long time ago, but not these days. If you use the correct tool and sized crimp there should be no need.
  3. Steve22537
    Steve22537 Full Time Elf
    Dec 13, 2010
    258
    8
    Harrisdale, WA
    Yes I still do, only because I haven't the right crimp tool, another 120 crimps to do...
    Steve
  4. Benslights
    Benslights Dedicated Elf Global Moderator Generous Elf
    May 2, 2010
    2,505
    183
    Elderslie
    buy yourself the crimping tool it is the best thing to do and saves a lot of time. mine also has wire strippers on it.
  5. David_AVD
    Jun 12, 2010
    3,951
    263
    Here's an example of a cheap crimp tool (Altronics) but I don't recommend them at all.
    Here's an example of a reasonable quality crimp tool from Altronics. This is the style to get.
  6. kool-lites
    kool-lites Full Time Elf
    Jun 26, 2010
    179
    0
    Baulkham Hills
    Although one wouldn't solder insulated crimps. Unless you like the smell of burning plastic.
    I dont solder crimps cause it can spoil the spring in the contacts.
    $5 crimpers will only give a $5 crimp. Buy the best you can afford. My Harwing and AMP crimpers are still top notch.
  7. Fing
    Fing Full Time Elf Generous Elf
    Dec 31, 2014
    394
    42
    Muswellbrook
    Surprisingly a proper crimped connection gives a better joint than soldering. Lash out and buy some good quality "ratchet" crimpers from an electrical wholesaler. Automotive type crimpers are basically useless.
    Fing
  8. Superman
    Superman I Have C.L.A.P and its very infectious Global Moderator
    May 29, 2010
    1,712
    44
    Ipswich-QLD
    Plus 1 for the good ratchet tool here
  9. fasteddy
    Apr 26, 2010
    6,636
    69
    +1 for this
  10. mborg10
    mborg10 Michael Borg
    Dec 28, 2011
    1,446
    1
    claremont meadows
    If you watch the youtube show mighty car mods there is an argument over soldering or just twisting wires together. A car has lots of vibration and solder joints can break where twisted wires can flex. No conclusion to this argument.
  11. plasmadrive
    plasmadrive Full Time Elf
    Jan 12, 2012
    244
    40
    Elk Grove, CA
    Being a long time control panel eng and manufacturer, I have a real hard time with this statement. Have you anything to back this up? I would be very curious to see the data..
    Crimp connections with the proper tool are very good, however, a solder connection done correctly is better as far as I can tell. Crimp connections in certain situations can have expansion and contraction issues over time with heat and cold. Solder not as much... at least in my experience.
    As well, by many codes and standards you can solder multiples of wires (more than 2) together as a single joint where as the same is not usually true of a crimp connection.... There are of course some exceptions..
  12. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    408
    6
    Chirnside Park, Victoria, AU
    Plasma,
    I think you missed one of the points at the beginning. They're talking about soldering a crimp connector onto the end of a cable and then putting it into a screw terminal. I have to agree that anything soldered should not be put into a screw terminal as the solder joint is likely to fail over time.
    If we are just talking about joining wires together, then you are totally correct, solder is better.
    Basic rule I learnt first year of my apprenticeship is that no soldered joint should be put under any mechanical strain, be it tension or pressure.
    Regards,
    Rowan
  13. plasmadrive
    Jan 12, 2012
    244
    40
    Elk Grove, CA
    Ah yes.. But help me out a bit.. When I built large ion laser supplies we always crimped then soldered the high power connections on fork terminals. The same is true for many motor connections from manufacturers and rebuilders. Those fork or ring terminals were put under screws and all was good. I assume no one meant this type of set up was not a good idea. (correct?)
    Now if you mean don't tin a wire or pair of wires and then put that under a screw directly, I get that part for sure.... That is bad juju
  14. multicast
    multicast Senior Elf
    Jul 13, 2013
    715
    8
    If its crimped, then its not soldered. Soldered joints shoud'tn be put under any mechanical strain.. Solder will creep.
    One or the other, but not both.
  15. Fing
    Dec 31, 2014
    394
    42
    Muswellbrook
    Hi Plasma,
    I've been in the industrial electronics control workplace for 35yrs and have always been under the impression that "crimp beats solder". Where this came from I don't know, so I accept your challenge to find some data to support or reject this idea ;) .
    to start I found this from a RF manufacturer http://www.rfcoaxconnectors.com/Technical_CrimpvsSolder.htm
    This site was also very interesting http://www.marinewireandcable.com/2013/11/crimping-vs-soldering-marine-cable-and.html
    Their drawback #4 which deals with crimp then solder addresses one of your other posts. they describe it as "functionally unnecessary", which is what I've always been told.
    This site has some interesting photo's, which i think gets to the heart of the matter. The question should be "which is better, for what application, and who/how are the joints made ?" http://www.stevemeadedesigns.com/board/topic/139795-the-ultimate-answer-on-solder-vs-crimp/
    But all this is insignificant against the real question…. "why is it that Americans don't pronounce the "L" in soLder?" ;)
    Fing
