tuppetsdad
Funding & Tech Support
Working on talking faces to mount on some of our mini trees . My plan is to use 12mm x 3 mm aluminium strip bent to shape and riveted. Then fit some edge lit strip.
Starting to make the frames
Frames are all done. Main issue is to design them so that the 50 mm cutting distance on the LED strip matches the frames.
And a close up of one
Next step is to finish fitting the lights and set up controllers etc.
