temp for pix4
Discussion in 'Advatek Lighting' started by Boof63, Nov 29, 2014.
  1. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    583
    31
    Kadina
    How hot is it safe to run pix 4, am trying to sort out matrix at moment , air temp is 36oC but pix 4 showing 44oC, have 120 cm computer fan running in 45 x 35 x 40 cm plastic storage tub, that's painted white to reflect and has lid covered and two sides covered with sheet to stop direct light??
    cheers Boof63
  2. nzlongfellow
    nzlongfellow Dennis from NZ
    Jan 2, 2014
    538
    0
    Lepperton, Taranaki
    Per the manual... Cheers
  3. OP
    OP
    Boof63
    Nov 7, 2011
    583
    31
    Kadina
    THanks again :-[ :-[ :-[
  4. AussieDoug
    AussieDoug Full Time Elf
    Dec 1, 2012
    375
    0
    Have you got any external ventilation or just a fan circulating the air in the box?
    That heat needs to be able to get out. Even fitting a couple of 1" PVC elbows on each end would be a big help.
  5. OP
    OP
    Boof63
    Nov 7, 2011
    583
    31
    Kadina
    Fan is bringing air in, and two slots where cabling runs out I thought might do , but yes I think I need to add extra venting should I be running the fan to suck or blow- seriously please.
    cheers Boof63
  6. AussieDoug
    Dec 1, 2012
    375
    0
    Mine are set up to blow the hot air out. Not sure if others have set theirs up the same.
  7. OP
    OP
    Boof63
    Nov 7, 2011
    583
    31
    Kadina
    THanks AD
    Boof63 :D :D
