Tension for Boscoyo mounting strip?
pistolpete2020
Hi all whats everyone use to tension the bsco plastic strip for pixels to be inserted..im using the top of the strip which will be mounted by screw to top of building but neeed to anchor it to the ground with some tension
Kartman
Cairns
I use threaded hooks which I check every day for the first few days while they stretch in the sun.
tooms
12v4life
Kalgoorlie
I tried the bungee ball things from Bunnings and like other's have said just couldnt get enough tension on them, and then I found half way through the season the elastic inside them had just given up. Big big cable-ties is all I use now
