testing new lights
Discussion in '101 Display Basics' started by Heath-LightsOnTapley, Sep 22, 2015.
  1. Heath-LightsOnTapley
    Heath-LightsOnTapley Senior Elf Generous Elf
    Aug 23, 2015
    594
    66
    sheidow park
  2. bjpc2716
    bjpc2716 who dares win
    Jul 11, 2012
    685
    12
    melbourne
    8) use avd test software
  3. Habbosrus
    Habbosrus Back again
    Dec 5, 2012
    756
    17
    Swansea, NSW
  4. AAH
    2,882
    171
    Those little $3 testers are brilliant for testing lights. Unfortunately some only have 2 wires out. If they are only 2 wire out then theoretically the wires should be 0V and data and the power to run the pixels will have to be supplied "around" the tester.
  5. i13
    i13 Senior Elf
    Jul 5, 2013
    804
    21
    You can't use test software unless you have an E1.31 pixel controller. These are not from Ray but you'll need one for your display.
    Just plug a string/strip into the pixel tester (first) and then apply 12V to the tester (second). There will be a limit to how many strings/strips you can run end-to-end in this configuration due to voltage drop but it'll confirm that they work.
  6. OP
    OP
    Aug 23, 2015
    594
    66
    sheidow park
    i have a pixlite 16, is that what you mean? cheers
  7. i13
    i13 Senior Elf
    Jul 5, 2013
    804
    21
    Yes that's what I mean and it's worth testing that with the test software especially if you can't get it working with your sequencer.
    I still suggest trying the pixels with the little pixel tester to make sure the lights work first.
  8. Habbosrus
    Dec 5, 2012
    756
    17
    Swansea, NSW
    The Pixlite will do the job nicely. You can hook up your lights to the Pixlite 16 and use da e131 to test. The test function in Xlights/NC is pretty good too, but da e131 is easiest and a great piece of kit.
    The little tester is the easiest, just supply power to v+ & v- & connect the other end to your strips/strings (one strip/string at a time though). Hit the button and away you go.
    Hooking up to the Pixlite will give you many more options and you can test each individual led with David's software
  9. gerry
    gerry Senior Elf
    Dec 19, 2012
    804
    5
    Surrey Hills,Melbourne
    The pixlite 16 also has a hardware test where you just press a button for 3 secs.
    Make sure u upgrade to the latest firmware and use the latest manual which explains which button .. I can't recall.
  10. Benslights
    Benslights Dedicated Elf Global Moderator Generous Elf
    May 2, 2010
    2,385
    121
    Elderslie
    I always use 3 things to test
    da e1.31
    test software on board
    then the software I am using for my display
