Because of the weight of steel, I want to change my current mega tree mast pole from steel to aluminum. It is currently 1 1/4 diameter about 20 total feet of steel pipe with a 10 foot piece of steel pipe on top of another 10 foot piece of steel pipe. These two pieces of ten foot steel pipe is joined in the middle by a very short steel 'coupler' that is female threaded that both of the 10 foot sections screw into. I have always thought that 1 solid piece is way better than 2 pieces threaded together by a coupler.
There is a aluminum vendor here that sells a 20 foot section of aluminum pipe either 1 1/4 or 1 1/2 diameter in either schedule 40 or schedule 80. It appears to be thicker than the steel (schedule 80) and 1/3 the weight. I'm changing the hook head to have the center section 'pinned' with two holes so that the hook head can be attached ANYWHERE on the mast pole. The old hook head center section was threaded and would only screw into the end of the threaded mast pole. This way, with the new hook head center design, the center section being a outer 'sleeve' over the mast pole, has more 'adaptability' if I want to slide the hook head higher or lower on the mast pole. The tree topper star has already been changed to aluminum and with it's design, I can slide it up or down the upper aluminum 3 foot mast pole.
See the photo. In the 2nd photo, you can see the mast pole made out of steel and the existing hook head made out of steel Out of the top of the hook head is an aluminum 3 foot pole in which the aluminum tree topper star frame is threaded into the top of the hook head. I eventually want everything to be made from aluminum. The steel is just too heavy. Very dangerous to install or remove. Too top heavy!!. Once this thing starts to tip, it's just an accident waiting to happen.
I can order a 20 foot section of either 1 1/4 or 1 1/2 in either schedule 40 or more preferred schedule 80. The schedule 80 is thicker than steel, more robust, and 1/3 the weight. Of course the cost is MUCH more.
Is there any reason why I shouldn't go to aluminum? With a larger hook head every year, tall height and the tree topper star frame up there, it is VERY top heavy and difficult to handle when installing or removing the mast pole with all that stuff on top. Any negatives on aluminum? --Greg---
