Tips on large pixel matrix installation
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by eastertime, Mar 31, 2015.
  1. eastertime
    eastertime New Elf
    Feb 24, 2015
    4
    0
    Hello,
    I have posted the following in another forum but was also wondering what members have to advise here.
    Could anyone offer any tips or things to look out for when building a large matrix? The matrix specifications are:[/size]Dimensions: 6 meters X 3 meters, divided in 10 cm pixels, a total of 1800 pixelsLED: Strings of WS2811, 12V, bullet pixel node, 12mmController: T300-KAny tips also regarding refresh rate when connecting such a large number of pixels?[font=verdana, arial, tahoma, calibri, geneva, sans-serif]Thanks![/font]
  2. mborg10
    mborg10 Michael Borg
    Dec 28, 2011
    1,446
    1
    claremont meadows
    1800 pixels should be fine. My mega tree is 2016 pixels ws2811 dc12v running of a P12r from jysys. Thru a standard $20 router Refresh rate won't be an issue.
    If your making a matrix 6m x 3m out of solid construction be careful it doesn't become a giant wind sale.
    Pixel spacing might be an issue At 10cm to see images it will be best viewed from about 20m's away or across the street in my case.
  3. OP
    OP
    eastertime
    eastertime New Elf
    Feb 24, 2015
    4
    0
    Thank you for the reply.
    The construction will be fixed permanently on a wall so size is not an issue in this regard.
    Thanks for the response.
  4. mborg10
    Dec 28, 2011
    1,446
    1
    claremont meadows
    10cm spacing with a minion image
  5. OP
    OP
    eastertime
    eastertime New Elf
    Feb 24, 2015
    4
    0
    That looks very impressive!
  6. nzlongfellow
    nzlongfellow Dennis from NZ
    Jan 2, 2014
    538
    0
    Lepperton, Taranaki
    My matrix has 2540 pixels at 35mm spacing. I run it off 2 x 350Watt power supplies as I never run everything on full white.
    4 channels on a Pixlite 4.
  7. Benslights
    Benslights Dedicated Elf Global Moderator
    May 2, 2010
    2,586
    229
    Elderslie
    4 channels????????? do you mean 4 outputs?
  8. nzlongfellow
    Jan 2, 2014
    538
    0
    Lepperton, Taranaki
    OK Ben yes 4 outputs with 630 CHANNELS on each output. AND that makes 2,520 channels before you do the calculations ;) ;) and check my 2540 statement. :D
  9. OP
    OP
    eastertime
    eastertime New Elf
    Feb 24, 2015
    4
    0
    Thank you for the replies. Has anyone here built a pixel matrix using acrylic perspex or plexiglass as a front cover? I have calculated as ideal individual pixel dimensions of every pixel as 80mmx80mmX100mm(Depth), for each pixel node, taking into account lumens of the 12V pixel node and beam width. However I may be wrong. Has anyone had any experience with installation such as this?
  10. BradsXmasLights
    BradsXmasLights WiFi Interactive
    Dec 23, 2010
    566
    40
    Brisbane, Australia
    If laying the matrix on the side of a pitched roof, i'd double the spacing between each row.
    Then it'll be easier to see when standing on the ground. Much like how they distort the aspect for signs on football fields so it looks better on camera.
