TM1804IC,DC12V
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by David_K, Nov 18, 2014.
  1. David_K
    David_K Full Time Elf Generous Elf
    Nov 10, 2012
    145
    4
    Hi Guys, need some help with the tm1804IC 12V lights, are they directional like the strip lights etc? if so how do you tell which direction to power up from? All I can get is a single node to light blue. Any advice appreciated.
  2. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    865
    3
    Karaka, Auckland, NZ
    With all pixel strips I assume there are arrows on the strip? If so, face the arrows going AWAY from the controller.
  3. OP
    OP
    David_K
    Nov 10, 2012
    145
    4
    Unfortunately I cannot find any arrows.
  4. David_AVD
    Jun 12, 2010
    3,922
    242
    There is sometimes text on the little PCB to indicate data in (DI) and data out (DO). You may have to slice one open to read it clearly.
  5. OP
    OP
    David_K
    Nov 10, 2012
    145
    4
    Thank You David, will take a look, I am a little concerned I have 12 x 50node strands and none seem to work. a couple have lit about 75% on two strands but only when I hold the blue wire in my fingers??? other than that most will not light and some have the first node light up but no others. These should work with the j1sys ecg-p2 or not?
  6. David_AVD
    Jun 12, 2010
    3,922
    242
    I have no idea on what pixels the P2 supports.
    Maybe post a picture of how you have the power and data connected.
  7. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    865
    3
    Yes the P2 should support it, I have TM1812 strip and it runs on the P2 with 1804/2811 type.
  8. OP
    OP
    David_K
    Nov 10, 2012
    145
    4
    Thanks for your input guys much appreciated, I seemed to have solved the problem I did not have the string type selected in the gateway. My only problem now is the colours are not as they should be, for example red is coming out as blue. Has anyone encountered this before?
  9. fasteddy
    Apr 26, 2010
    6,636
    67
    This is the RGB orientation and is a very common thing to not be in the incorrect order, but the controllers support this change in the configuration screen as you can change the RGB orientation to suit your lights.
  10. OP
    OP
    David_K
    Nov 10, 2012
    145
    4
    Thanks Eddy, all solved now. As soon as I seen your comments I remembered reading about this in one of the excellent publications you guys did. Thanks for everyone help without this forum I doubt I would have ever made the change to rgb and animation.
