grahami2006
When I have applied transitions some of the channels are not showing that effect. I have a megatree which is 40 pixels by 16 strings. The channels with nil effects are 1-15, then 106-135, 226-255 and so on.
Thanks Eddy fixed when I mapped to stage.ɟɐsʇǝppʎ said:If you are using some of the video transitions that when viewed in the preview sceen show black at the bottom or top then this is what you will get when you use this effect.
See if map to stage works for you, or if thats not good enough then recode the video so it fits within the preview window and doesnt have any black bits at the top or bottom of the preview.
Map to object will map the effect directly to the object or group of objects with the effects generated within the boundaries of the object/s chosenɟɐsʇǝppʎ said:If you are using some of the video transitions that when viewed in the preview sceen show black at the bottom or top then this is what you will get when you use this effect.
