Transportable Pixel Sign Construction
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
1220mm x 2440mm sign.
2450 12mm holes drilled today. Now starting on frame.
More pics to come as it progresses.
zoobmarine
If you are going to use nodes I suggest you use 2 sheets of coro, this will keep the node in place always, I used a pencil soldering iron to make holes was very easy, and after heating y placed the node the warm of the hole make it easier to place the node, when it got cold it fixed very good
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
I have made all my other holes for nodes with an iron just as you say and I do get a nice fit but the reheat time is slow sonot bad for 100 odd holes but not 2200. I am getting a good tight fit with the drilled holes.
zoobmarine
Well it is a hard work, good luck, thanks for sharing, would like to see the sign finished!
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
Well today, of all days, Ray's pixels arrived - right on time.
10 nodes in only 2440 to go.
your definetly commited, should look great when finished
Im lazy as i would have used strip instead
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
My fingers agree that strip would be easy but I like the crisp definition of a node.
600 installed last night.
I need it completed by the end of the month as a Karaoke style board for a concert I am doing.
Words and tunes in xLights. Should be fun.
