VU Meter help
cdbrown
Perth
Hi,
I've got a party coming up and thought I could put the 8 x 2m strips I have to some use and make them display as a VU meter moving to the music. I'm really not sure what I need to get this to work. Was hoping to perhaps run Pandora or spotify on the Rpi and stream the music. Is there a program I can install on the rpi that would monitor the music and then output to the strips via the ECG-D2.
I really don't know where to start to look for this so hopefully someone here knows.
-cdbrown
i13
xLights has a VU meter effect. Export xLights sequences onto the Raspberry Pi running Falcon player.
Grandpa Elf
The OP mentioned streaming music so would need to do it in real time, not programmed.
The project Alec linked to looks promising.
JPB
Glenwood
I know you want to use your existing Pi but I also know that you can do it very easy on an arduino uno. I played around doing this a couple of years ago using sketches I originally found on Indestrucables.
