What type of wire for sending data?
Dez
Toowoomba QLD
Happy new year to everyone!
I have read so many many things about what types of wire people use and now I am confused.
Hypothetically, if I have a falcon f16v3 controller and I am just running data out to my pixels (power injection out at pixels), what type of wire do you guys suggest for this? Do you use 2 core or 3 core? Maybe basic electrical cable?
If it's data and ground only then security cable or cat5 cable is just about as cheap as you can go. If you are needing to run the Null Pixel Buffers as discussed on another thread then allowing 1 core for 5V or 12V power is good. Only 1 core should be used for data and all the rest of the cores for 0V/ground.
Dez
Toowoomba QLD
Thank you but I’m confused. Yes I would be using the null pixel buffers but from what you say these do not run on the data wire? I thought I only needed 2 wires, one for data, one for ground?
Benslights
Elderslie
with pixel buffers and your pixels if 2811 you will need 3 wires
data
+ve
-ve
I use 6 core cable for my cabling
1 wire for data
2 wires for +ve
2 wires for -ve
The nulls can be powered from either the controller or the pixel end. They need a few milliamps to run them so light duty wire is all that is required. You could, if you desired, just run 2 wires/conductors from the F16 to the Nulls and 3 wires from the Nulls to the pixels and power injection. Alternately you could run 3 wires from controller to Nulls and supply the Nulls with the power from the controller end and then 2 wires/conductors to the pixels and injection point.
Dez
Toowoomba QLD
data
+ve
-ve
1 wire for data
2 wires for +ve
2 wires for -ve
Ok thank you. Why 2 wires for ve?
Dez
Toowoomba QLD
Thank you. I will look into getting some security cable
