Wiring 2014 Coles LED Strings into 2811DC30
Discussion in 'Lights - Store Bought and Home Made' started by franky_888, Nov 18, 2015.
  1. franky_888
    franky_888 Apprentice Elf
    Dec 31, 2013
    59
    2
    Medowie
    I need the assistance of the electrical gurus here please.
    I've got a few tubs of coles led strings from the 2014 christmas season, they are 3 wire from the MFC and I want to wire them into a 2811DC30 controller.
    Here are the pinouts...
    Controller:
    String:
    Label:
    I powered the string up and set the controller to steady on ie all lights on solid. I then disconnected the lights, pulled out the multimeter and measured between the pins on the mfc. Here are my findings:
    -ve +ve voltage
    Pin0 pin1 +30v
    Pin0 pin3 +30v
    To me, this means that the led strings are common –ve, and that pin0 is the –ve, leaving pin1 and pin3 to be +ve string 1 and string 2. Is this correct?
    If so, as the 2811DC30 is a common +ve controller, the voltages would be around the wrong way to control these lights I’d assume. To address this I believe I would need to wire 1 string between 3 channels so that the voltage runs the right way through the strings Eg +ve to +ve on the DC30, then –ve into channels 1,2 or 3, and control only that channel, meaning I could only control up to 10 of these strings on a DC30 board. Does that make sense?
    It seems like a waste but this is only to make do until I can order some custom strings next year hopefully.
    If I’ve done something completely wrong here I’m more than happy to be corrected. Thanks in advance.
  2. David_AVD
    Jun 12, 2010
    3,862
    218
    Maybe try hooking the string to a DC power supply. I don't think you can't really cause any damage with incorrect connections.
  3. OP
    OP
    franky_888
    Dec 31, 2013
    59
    2
    Medowie
    Nice suggestion, I didn't think of that.
    After testing it appears my pinouts are correct, but my current flow is not. The strings are common +ve just as the old BIGW strings are (FYI for the future).
