Quick wiring question. I have a F16V3 controller. I'm not going to power any lights from the controller. Do I just run data and ground from the controller and then inject power and ground from the individual controllers to the lights? Also by doing it this way. Will that also provide a common ground between the controller power supply and the individual power supplies or do I have to run a seperate wire to tie them all together?
Oh and one last question on this setup. Should I run a fuse on each individual power injection line or can I run one fuse to a busbar and run the individual power drops without a fuse?
Thanks for your help
Greg
Greg
