Xlights sequence loading issue No Lights on a completed sequence
Greetings and salutations! So I've been having this issue on and off again with xlights. This time it is not correcting itself. So I have completed my sequence months ago. It played fine with no issues. I went to load it in xlights and after it came up the lights do not appear. I hear the audio but no lights. When I click on a effect sometimes the lights will come on but on the wrong prop. In the past I would render it and it would correct the issue. But not now. The only thing I've done recently was change the FSEQ file to version 1 (uncompressed) on the sequence to export it to a program so I can run it on my Holidaycoro Hinkspix pro controller. Any clues as to why this is happening and a way to correct this? Thank you in advance.
