Release 2023.23 Released
keithsw1111
Kellyville, NSW
2023.23 Dec 28, 2023
— enh (dkulp) Convert “New Style” Pinwheel effect to use Meta GPU rendering on MacOS
— enh (scott) Added Scheduling to HinksPix Export Dialog.
— enh (scott) Persist Custom Colors across Color Dialogs.
— enh (dkulp) Update to newer version of wxWidgets that fixes appearance of checkboxes on properties panels
— enh (keith) Bell at end of Batch Render, extra progress displayed during batch render
— enh (keith) Allow user control of maximum Render Cache size
— bug (scott) Fix Import Dialog AutoMapping Aliases to Submodel/Stands.
— bug (scott) Fix Import Dialog Groups Blue turning white.
— bug (scott) Fix 3D Model Export starting at zero.
— bug (scott) Fix DMX Shutter value with On effect and Flood lights.
— bug (keith) Fix crash with parsing JSON with certain UTF-8 characters
— bug (tulzscha) Fix fire effect buffer sizes
— bug (dkulp) Fix some random crashes that occur with various actions on the View Models panel
— bug (dkulp) Fix discovery of Falcon controllers as remotes if needing to use http discovery
— bug (dkulp) Fix potential crash/memory corruption at startup when resolving IP’s on background threads
— bug (dkulp) Fix leftover files remaining in tmp directory
— bug (dkulp) Fix some problems writing ZSTD fseq files for layouts with well over 2M channels and complex effects
MikeKrebs
Remember that if you are on 2023.20, it won't correctly check for updates so you need to do the download yourself. Not sure if it affects other versions.
