Will there be a group buy for these boards an parts?
I didn't see the resistors and caps in SMD being as much of a build problem as the ICs which have such closely spaced leads. I'm looking at getting back into hardware design and the one thing I worry about it building prototypes with SMDs are the IC as I'll need new soldering station, 3D microscope and other items I never needed with through hold components.AAH said:There's about 120 SMD components which makes up almost everything except the 60 mosfets and the connectors. Without fully assembling the boards there is no way for me to test them or to install the firmware. The original firmware will need to be installed via the ICSP programming header but all public release firmware will be via downloads that can be installed via a thumbdrive.
AAH said:The voltage reduction is done via PWM which is the same method used to dim lights. It's a pseudo voltage reduction really. As far as the eye and metering it goes it will look and measure as the lower voltage.
