brando
First year show this year, have got my first mega tree up.
4m plus topper - 40NB steel pole, was 6.5m length cut into 4m & 2.5m (also building a smaller 22 * 100 tree)
24 * 150 @ 1" - 3,600 total plus 150 for star
5V bullets
Running off 5 ports of a He123Mk2 (4 for tree, 1 for star)
Power injection every strip
Portable hole
3 guy wires to a guy wire ring just below topper (not here to debate correct/best location) - these connect to heavy duty temporary fencing bases with eye bolts
Base in a mini trampoline with j bolts, nut to tension
Sand bags all over the place for the extra weight
Boscoyo 36" 6 ring star (only using 3 rings this year) - I have a 15mm galv flange on the spigot bolt, 15mm galv threaded pipe - I have my star with 2 guy wires to the topper to stop it spinning
It's essentially just been thrown up this weekend for testing, not completely tensioned or in eventual location.
I was actually really intimidated by this but am pretty happy with how it's turned out.
My takeaway - I should have / will do, use a winch system. The put up and down, I didn't find the weight was too much of an issue, as much as keeping the strings from getting all messed up
Running off 4 ports. With strings of 900 each, the obvious concern is one dead pixel taking out a quarter of my tree. I intend on changing this to run off 25 ports by using a He123Mk2 with expansions, one string per port plus one for star.
It's a complete mess, but as I said, it's up, tested, works well and pretty happy with it.
Summary takeaway - unless you can get to the top of your tree on a ladder or similar, use a pulley or tilt up option.
Power injection - I don't find it difficult at all, it's pretty straight forward, I just find it to be a pain and extra time when the alternative provides more positives imo.
