videoman3857
I have a CMB16 board I cant get to operate.
I set the rotary unit address switches to correspond with my controller id as selected in Sequence editor and nothing happens.
I have run the hardware Utility, refreshed the Select unit to configure and it displays a totally different I.D
If I select 0 on the first switch and 8 on the second the auto detect displays 0A.
If I set to 0 and 1 the auto detect displays 03
When I use Light console and select the unit ID as per the address switches and test, nothing happens
If I set the console to the "Detected ID" and test - nothing happens
I have run a voltage meter on all outputs and get a zero voltage reading
The red board LED flashes when powered up and is then steady when I connect the cat cable
Any ideas ? ?
I am guessing it is more than just the rotary ID switches
Any ideas ? ?
