tooms
12v4life
Hi,
I would like to make a suggestion though with the Advatek Assistant application, it would awesome if you could manually specify the IP address for the board as well, I ask this because I use a rasberry PI to drive my lights but I have 2 ethernet interfaces on the pi to segregate my home LAN from the lights LAN, I note the controller does accept data from outside it's subnet, but the assistant application cant connect to it unless it's on the same subnet.
Once again, just a suggestion, thanks for a great controller.
Regards,
Daniel
Regards,
Daniel
