Falcon Player - Official v0.4.0 release is now available
CaptainMurdoch
The Falcon Player v0.4.0 is now officially available for download via SourceForge.net.
Thanks to all of those who helped us test by downloading the beta-test SD images.
The new v0.4.0 image is available for download directly at
https://sourceforge.net/projects/falconpiplayer/files/latest/download
For support, please visit the Falcon Player support forum at
http://falconchristmas.com/forum/index.php/board,8.0.html
Changes in v0.4.0 include:
* Support for Raspberry Pi models B and B+
* Updated NOOBS to version v1.3.10
* MultiSync feature
- Sequence synchronization between multiple FPP instances (Master/Remote)
- Auto-discovery of other FPP instances on the network
* Ability to change the hostname via the FPP UI
* GPIO Input triggers (native GPIO and PiFace Digital I/O board)
- Supports both Normally Open and Normally Closed contacts
* Date-based scheduling
- Schedule playlists to only run within certain date ranges
- ie, one playlist for Feb 14, another for July 4, another for Dec 1-31
* Event Control Channels UI
- Allows triggering events via data in your sequence file
* Memory Mapped Channel Blocks
- Allows direct channel data manipulation before output to lights
- FPP::MemoryMap Perl Module
- fppwss Web Socket Server
- Matrixtools plugin for dynamic text or drawing with a mouse on a matrix
* Falcon hardware compatibility
- Add support for pass-through of configuration data to Falcon hardware
- Auto-detection of Falcon hardware (running newer firmware) attached to SPI port
* Minor enhancements
- Setting to force analog audio output during video playback
- Performance optimizations
- ChangeLog viewer
- Simplify log configuration UI
- WS2801 channel output extended to support 1530 channels
- E1.31 bridge mode now has consistent output frame rate not tied to input packet rate
* Multi-platform preparations to allow future support on non-Pi devices
* Bug Fixes
- E1.31 bridge mode with both WiFi and Ethernet in use
- UI fixes (playlist editor, scheduler, etc.)
- Renard Output code
- Plugin callback code
- Disabled power management on WiFi interface to fix dropouts
- Auto-detection of fallback IP to work around IP conflict
CaptainMurdoch
Sorry for the double post, I didn't realize Tony had posted this last night. This may be an more appropriate forum for the announcement though.
Superman
Ipswich-QLD
Cheers Captain, We don't mind the double post as long as we don't miss out on the info.
Steve
