firebat
- Jun 5, 2019
Hi All,
Firstly, awesome community you have here lads!! Everyone is super helpful and keen for lighting madness!
Shoutout to @darylc who is a uber legend sending through a special edition F16v3 quick smart.
So anyway.... I've been reading, searching and attempting to answer my own questions first.
But now I'm hoping to get a bit of reassurance that I'm headed down the right path. I'm centring on a 5v WS2811 pixel system.
Control will be handled by a Artnet/sACN controller outputting to a Falcon F16v3 then onto the individual pixel chains.
I'm wanting to achieve per pixel control as I may want to 'Pixel Map' the entire system with a video source at a later time.
12v would have been preferable because the run distances from the controller to the pixel groups could be over 20m, but I believe the general IC configurations wont allow for per pixel control at 12v.
Below is my intended purchase list, any suggestions/pointers would be very welcome!
So for the gear list:
Falcon F16v3 1x
https://www.pixelcontroller.com/store/index.php?id_product=48&controller=product
Pixels (50 String) (with 13.5mm male/female ends) 20x $14.55unit $291USD https://www.aliexpress.com/store/pr...xy-resin-filled-50pcs/701799_32259805463.html
Data Repeater 10x $1.46unit $14.6USD https://www.aliexpress.com/item/DC1...-5mm-3-core-black-waterproof/32279633328.html
PSU 2x $42.19unit $84.38USD https://www.aliexpress.com/store/pr...00-240V-input-5V-350W/701799_32493342899.html
Tester 2x $3.64unit $7.28USD https://www.aliexpress.com/item/DC1...tterns-2048pixels-controlled/32261096741.html
Cable T - Type Power Injector (10pack) 1x 27.65unit $27.65USD https://www.aliexpress.com/item/3-c...LACK-color-the-male-connect-s/1707253215.html
Cable 3pin Female Tail Set (10 Pack) 2x 5.82unit $11.64USD https://www.aliexpress.com/store/pr...y-13-5mm-series-18AWG/701799_32741667567.html
Cable 3pin Male/Female Tail Set (10 Pack) 2x 7.28unit $14.56USD https://www.aliexpress.com/item/10p...e-and-female-male-connector-s/1019853359.html
Cable 2pin Male/Female Tail Set (10 Pack) 2x 5.82unit $11.64USD https://www.aliexpress.com/item/10-...le-and-female-13-5mm-diameter/1485623749.html
50m Cable 1x 34.92unit $34.92USD https://www.aliexpress.com/item/50m...AWG-cable-for-led-pixel-module/715333070.html
3m 3pin Extention Cable (10pack) 1x 32.01unit $32.01USD https://www.aliexpress.com/item/BLA...-with-male-the-other-end-with/1343193048.html
End Caps (10pack) 4x 0.73unit $2.92USD https://www.aliexpress.com/item/pla...-5mm-BLACK-waterproof-pigtail/1019809775.html
Falcon F16v3 1x
