Garage Matrix Builds
Clegg
Pakenham
So... I did the totally-stupid-and-not-recommended-time-sink way of doing a custom matrix.
The plan was to make a 100 x 44 matrix to fit a 4.75m wide garage (so... 47mm separation, just under 2") so that in sections I could keep all wiring to one side of the panel. To handle power injection, I ordered strings with power injection wires so that I could inject what I expected to be long runs (600 odd pixels).
Bunnings had the large sheets of twin wall for $29 each so figured I'd use that to make the panels, and a few cans of Rustoleum black matte spray paint. I 3D-Printed a 4x4 jig with a 47mm separation between the 12mm holes with the first quadrant with 'pegs' to fit in previous holes. This worked to an extent, but as the Jig worn down towards the end, it came up a little 'wavey'. For the remaining three sheets, I clamped them together and drilled straight through the 1,100 holes so that they would roughly be identical. After cutting them down to size, I flipped two so that each 'edge' would line up and well... from viewing distance looked fairly straight on the panel.
Mounting was a tremendous amount of procrastination. I wanted originally to go the temporary fencing route, but I didn't know if this'd work and I'd rather not turn my brick into Swiss Cheese if I could help it. After a lot of research for different mounting options, a lot of e-mails, I gave up on that idea and ended up getting some very strong magnets off Amazon to hold up a sheet with 1,100 magnets on them (https://www.amazon.com.au/dp/B08GCFSFJC) and drilled in several of these (https://www.bunnings.com.au/flexi-storage-home-solutions-300mm-black-double-slot-wall-strip_p2583635) at the top of each panel and cable-tied to the magnetic hook. A crude job that worked - you just need to weight / tie the bottom so that wind doesn't catch and tear it down (and also assumes you have a large lintel capable of giving you some good magnetic strength - those Amazon ones are strong.
So... yeah - a massive time sink to drill it all by hand, spray paint, populate the pixels but I was happy with the outcome. As I'll need to replace the pixels next year, I'll probably give it another go but do sections and magnet it to the garage door instead. I probably won't bother with upgrading the spring or anything - just unplug the motor for the few weeks and manually hoist it up if need be. I'm also in the market for a smallish CNC machine next year so I might give it another custom go.
I did mine for effects - and for that, it's absolutely brilliant (when you're not losing several pixels a night) and hopefully given more time next year some more 8-bit / pixel art graphics. If you wanted to do video, the ~1.8 inch separation isn't great unless you're ~15m away from it. The flashing lights sequence though was alright from the footpath.
Adsy
Sheidow Park SA
I considered doing this myself but drilling all those holes put me off . I am hearing you regarding pixel replacement. Worked perfectly for a couple of weeks and BAM!! another daily job 🤬
Clegg
Pakenham
A few additions to the above, for temporary fencing I considered different feet options:
- TempFence Super Store (feet that could be dynabolted to the concrete): https://www.tempfencesuperstore.com.au/products/temporary-fence-foot-metal-foot. Postage is crazy high, and I really had no reason to head over to the west to buy them).
- Cheap fences ($57.20) in Dandenong (https://www.victoriascaffolding.com...g-for-sale/temporary-fencing-panel-melbourne/ and https://www.ebay.com.au/itm/224039274040). These also ended up in an eBay sale of all things with 10% off, so if near Dandenong you can get them really cheap.
- Top Hill "Dog Fence Feet" (https://tophill.com.au/product/mesh-panel-steel-feet/) - these are also available in Warragul if in the east but they never got back to me.
- "Zero Trip" Feet (https://www.ttfs.com.au/products/zero-trip-fence-base/) - unfortunately they don't sell these anymore, but thought I was onto a winner here given I could get these flush up against the house without drilling anything.
For the controllers, I posted the photo but didn't mention it. The matrix ended up a custom model so I could do the strings in lots of 300 (for the first 900 per panel) and the last 200 on the fourth port. These were all done using the HE123 controller with the TX / RX modules and 20m Ethernet cables. They were paired with some spare 400W Rextin (generic?) Power Supplies I had from the first year. At 80% all white, 300 pixels were pulling 7.2A. I had set up power injection where the first LED was connected to the last LED in a local power injection configuration - that kept all pixels lit well without requiring the power injection services of the Distro next to it. The display was ran at 45% brightness so plenty of headroom on the power supply and boards.
brando
Ormeau, Qld
View attachment 21957View attachment 21958View attachment 21959View attachment 21960View attachment 21961
I built mine this year and got the design for mine from https://auschristmaslighting.com/members/30249/ but decided to go with the half panels clipped together using conduit clips (links below) as it was easier for folding away for storage in my shed and also less obtrusive during the day as I am able to fold them closed after each night and clip them to the walls. I used a strap to tighten the two sides together as without it the joins wouldn’t fully straighten out. I found that a node fit in nicely in between the joins between each panel with the spacing I had. You can get the clamps for these panels but I found they didn’t work for my needs as I wanted to be able to fold them after each show so used the conduit clips instead and used zip ties so they wouldn’t unclip. I need to clean it up a bit for next year as the two sides don’t quite line up but otherwise it has worked really well for me this year with no issues.
what is the bracket you have anchored into your bricks that the panels sit on?
brando
Ormeau, Qld
I had my Merry Christmas sign in front of my garage this year, I intended on replacing it with a big matrix next year, but it proved a massive hit for families to take photos in front of.
It, and my matrix were both on temp fencing panels from Bunnings. The Merry Christmas sign I had anchored in the concrete temp fencing feet at one end, and the other end I had the jockey wheel you buy from Bunnings, but also welded a longer leg onto this with extra wheels to make it easy to open/close like a gate.
I don't go into great detail but you can see it in my BTS below
Spoiler content hidden. Log in to see this content.
djgra79
Cranbourne West
Reading all of this and wondering why some of you are re-inventing the wheel? Troy sell's matrix panels.
1" spacing: https://www.extremelightingdisplays.com.au/shop/christmas/matrix/chromamesh-1/
2" spacing: https://www.extremelightingdisplays.com.au/shop/christmas/matrix/chromamesh-2/
I've got the 2" version and it's performed very well.
Yes but this material doesn't just stick to the garage itself. Depending on the type of door you have (roller, panel, tilt) and if you still want to use the door/garage during Dec means you need a solution to mount something in front of the garage doors.
vk3heg
Ballarat
Some of the posters have shown they are using temporary fencing, so just attach it to that.
djgra79
Cranbourne West
That's exactly what I plan to do after seeing a few examples here
mikey
Just go straight to a commercial P3 or similar screen. 500mm x 500mm building blocks, IP panel, just link power and data. Takes a HDMI from xschedule spitting out a virtual matrix. D8BD7A6C-0A1B-4800-A8FD-5FBD9EBEA33D.jpeg
