HE123-RX Receiver
John_82
I have a question around the compatibility of the Kulp K8-PB and the Hansen HE123-RX differential receiver.
The Kulp boards support both smart and differential receivers.
The Kulp Manual states:
“Each RJ45 port can connect to one Differential Receiver or up to 3 daisy- chained Smart Differential Receivers”
I’d like to try connecting 3 x HE123-RX receivers to the 3 differential ports on the Kulp board but not sure if the communications used is an open standard that I can cross vendors with (Although kulp and falcon seem to support each other)
If anyone has tested this would be great to know.
John
My HE123-RX boards work on Falcon F48 so presumably it would also work on a Kulp board. They aren't daisy chainable but each of the 3 outputs on it can receive 1600/800 (at 20fps/40fps) pixels.
John_82
Thanks, I’ll order one and test and if all good order a couple more
  • Like
Reactions: AAH
John_82
Just an FYI, I can confirm the HE123-RX receiver works as a standard differential receiver with the Kulp K8-PB boards.
Great option for an inexpensive receiver
John_82
@AAH are you able to tell me what the R10 vs LD1 indicator lights mean?
I had a look through the HE123 manual on the website but it just says “power led” (or maybe I missed it)
It just a power led to indicate that there is 5V coming from the regulator.
John_82
Thanks, I’m still. A little confused
I have three of these boards connected to different 12v power supply’s, two of them show green LED indicator on LD1 and one of them shows a Orange LED on R10?
I haven’t connected any lights to the one that shows R10, is this something I need to worry about ?
I use whatever led I happen to have handy at the time. I would generally use red or green ones but I do know I have used both white and blue when I run out. If there is a led loaded in R10 I have had an eyesight fail and have swapped the resistor and led. They can go in either spot.
John_82
Awesome, thank you!
Just wanted to check if it was anything to worry about
  • Like
Reactions: AAH
