Incorporating pool lights
Iain
Darwin
Well yes but the brightness thing still comes into play, COBs don’t usually come in colours so there would be no point using those with a 2 wire controller, and other LEDs are probably too dim…
Iain
Darwin
In case anyone is interested I've been researching and looking for ways to plug this all together. I've bought 4x 20W COB LEDs from Ali Express. The specs are probably a bit exaggerated as usual but I figure one will give me around the same brightness as a 100W halogen. If not, I can run 2 per enclosure at 80% or whatever.
These COB LEDs are actually "manufactured" with multiple smaller LEDs on the one board (hence chip-on-board or COB). Because of that you can find them in various series or parallel (or both) configurations, mix-and-matched (during manufacturing) to be almost whatever voltage you prefer. I've chosen 36V because that seems to be one of the common voltages for power supplies and LED drivers.
Now to the driver. Ideally you want a constant-current LED driver, because as LEDs heat up (and COBs heat up quickly!) they draw more current, and as they draw more current, they heat up, and you can get a runaway happening. However, you can use a typical (constant voltage, although they're called regulated) power supply connected directly to the COB if you have to. Nevertheless for 20W of LEDs in such a small package you need to cool them well. I'm counting on the large metal backing plate of my pool fitting to transfer the heat into the water... Wish me luck!
To dim the COB LEDs you usually use a driver with a 1-10V input for a trim pot (which is what you would connect for a typical wall switch dimmer) and the driver takes care of dimming the LED. You can however use voltage PWM if you're not using a constant-current driver to dim the LED, and I figure because it's modulating, it will keep the heat down a bit, and I can always set a max limit of 80% if I have to. This is what I was going to do with a Meanwell LRS-75-36...
As for the Christmas display integration, I am going to use the Hanson Electronics 2811DC15. I only need 2 channels but I can repurpose it later if I change my mind. This will take the WS2811 feed and give me a PWM output on up to 15 channels, but I'll only use one for each pool light, so 2 total channels. (May put some garden lights up with the rest). All I have to do is get a 36V power supply to feed into the 2811DC15, and connect the output to my LED...
That is, until I found this little doohicky: It's a Meanwell HBG-100-36, IP67 rated constant-current LED driver.
But the kicker is it can dim with a PWM input as well as the usual 0-10V variable input... (maybe they all do this but I never came across it before) which means I can connect the parts like this:
WS2811 controller => Hanson 2811DC15 => Meanwell HBG-100-36 => COB LED. This gives me constant current LED control integrated into my Christmas lights display! 🎉
This means I will have to run the 2811DC15 from 10V to ensure it outputs the correct PWM voltage to the driver, but that is fine.
Maybe I don't need the extra driver and I could just control the LED with voltage PWM, but I like the constant-current protection from over-heating.
Hopefully I can plug all this together in February for a test!
Iain
Darwin
My COB LEDs arrived some time ago, and the Meanwell drivers I purchased from Power Supplies Australia arrived last week. So here is a quick test of one 20W COB LED from AliExpress.
It's hard to get the brightness on camera as all my cameras auto-adjust, but these are seriously bright. I'm hoping one is equivalent to around 100W of incandescent light, and it sure feels like it.
The driver is fairly responsive to a 100K Ohm pot I'm using for dimming, but whether it will be good enough when I hook that up to my lighting display, who knows. Even if it's not I'm more than satisfied with the project as a cheap pool light replacement! And if they fail soon, then it was a huge learning experience. This was a nice end to a busy weekend!
Here's the LED on an aluminium plate. The bulldog clips are just for holding it to the plate with thermal paste underneath:
Here it is on at low brightness:
And at full brightness (not that you can tell in the photo, but it is a vast difference):
Here is a video:
Iain
Darwin
It’s slowly getting more permanent! Now all I have to do is solder the terminals, waterproof the new seal, and put it back in the water…
Iain
Darwin
So preeetttyy!
here’s a video of me adjusting the pot manually:
Indigogyre
Journeyman Elf
Wow, that's impressive that you can light up the entire pool with only a few of those pool lights. I'm looking forward to seeing sequences on it. :)
Iain
Darwin
Thanks! Unfortunately I didn't realize this dimmer only goes from 10% - 100% so there's no "off". I'll have to see if it washes out the pixels or not, and maybe add a relay in the mix.
Iain
Darwin
After a few months the LEDs stopped working... I pulled them out and they work on my bench (mostly) but there's been some degredation - possibly because they were cheap or possibly because a tiny bit of water got in.
I've used the opportunity to redesign it a little bit. Instead of the meanwell driver which needed a 0-10V source to dim, I found some DMX LED drivers which I can plug directly into the Falcon. The advantage is they can dim down to zero, and I don't need to develop anything myself to convert DMX to 0-10V.
I also purchased a couple of CREE COB LEDs, now that I've proved the idea I hope they'll last longer.
The only disadvantage is that I could only find constant voltage DMX drivers, not constant current, but I have a 36V power supply so we'll see how that goes...
Iain
Darwin
Version 2 bench test. Dimming to zero works well, as does functioning like a normal light without a DMX master. Next test will be a full submerge…IMG_4192.jpeg
Iain
Darwin
Yes I’ve essentially made a constant voltage driver, but I couldn’t find a constant current LED driver with DMX control that dims to zero… and capable of the necessary current.
