A question that is asked all the time is "How do i work out what resistors are needed".
Firstly we will assume you are using DC voltages.
There is a few things you need to know.
What is the overall source voltage to the string? ie 24v
How many LED's in a section of series connection? ie 6
What is the Forward Voltage (Vf) for each LED? ie 3.1
What forward current will be used? ie 20mA
Things to remember:
1. Forward Voltage (Vf) varies for each colour. Generally Reds are from 1.9 to 2.1, Green/Blue will range from 3.0v to 3.4v.
2. Leds in one colour can have different Vf figures even withing the same batch, especially true of really cheap LED's.
3. Accurate resistor values can only be found by actually measuring current flow.
4. All Vf figures in specifications are usually for a 20mA current.
5. Actually Forward Voltage drop will vary based on the current flowing.
Once you have answers to the above questions the simple way is to use the LED Calculator over at http://led.linear1.org/led.wiz to get a starting value for you.
The LED series/parallel array wizard will give you nice diagrams and clearly show series parallel LED setups.
What about those 24v 100 count red LED strings we can get, just go to the wizard above and enter 24v, 2.1v, 20mA, 100 Leds then look at the 10x10 array that is shown at the bottom of the page.
This is the series parallel connections that would be in the string of lights.
I call each set of 10 series LED's a "SECTION" and the complete set a "STRING". You will notice that the entire string draws 200mA.
One thing that can be highly confusing is when looking at a string of say 24v Big-W Blue leds that are 120 leds and have 10 LEDS per section and NO resistors. The astute reader will have already realised that Blue LED's have a Vf of 3.0v to 3.4v (at 20mA) and that 10 x 3.0v = 30v about 6v higher than the nominal 24 rating. Measurements clearly show that at 24v these strings only draw a few mA and are just glowing. The 20mA / section is not reached until the voltage is raised to 31v-32v which clearly matches expectations based on forward voltage specifications.
The manufactuer in this case is clearly using a lower voltage than the total Vf to do the current limiting rather than use resistors.
Phil
Things to remember:
Phil
